Builds HDJ80 LHD #snlcbuilt Ute (pickup) (2 Viewers)
So these arrived.
I test fit them to one of my radius arm mounts.
I like it, press fit on this one but I am going to weld them in. Spaces the mounts 3/16’s away from the radius arm. Should help my flex! 😂
Can’t fit the panhard to the front of the radius arm mounts, not enough room so I will be trimming them down before welding on. Also have a plan for the panhard, wait for it! 😝
Cheers
Accutune had said late August for my shocks, got an email this morning saying they shipped today. 😆🤷‍♂️
Ordered the 70-series frame side coil buckets out of Japan. It’s just easier than hacking off and cleaning up the ones still on the frame here.
Cheers
Were they easy to work with to get 80 Series shocks? I was just on their site and saw that they only have 200 Series listed as compatible vehicles.
Fox or King?
Fox or King?
Fox, very easy to work with. I went eye to eye on the shocks so they are a universal application. I don’t believe FOX makes a bolt in 2.5 remote resi for the 80.
Cheers
We are just finishing this up on a customers build.
I would like to build something like this for the 🐷 but man it is a ton of work! I will probably just do tube instead! 🤗
Cheers
Hot as can be here, dry heat though which I prefer.
I was going to go camping this weekend but it’s just to smoky and fires are limiting access.
So, I am going to work on the 🐷 during the cooler hours this weekend as much as I can endure in this heat. 🥵
Cheers
Welding out my radius arm mounts on the axle right now. Just a quick break for a cold beer! 🥵
Cheers
Ran out of gas this morning and bummed a cylinder from my neighbor. Just ran out of wire but it’s 90% welded.
Still need to cut a piece to box the front in, otherwise done.
Cheers
Almost 12hrs in the shop today, although I have been having cold beverages the last hour and just mostly standing here thinking. 🤘😂🤘
Pretty happy with this.
Good thing is if or when I want to change the suspension (albeit keep this whimpy 8”) I can just plasma cut it all off and start over. 😆😂
Cheers
  • Back
