HDJ80 Exhaust Manifold Leak? - How to fix? How does this joint work? Ok to drive?
Annapolis, MD and Uvita, Costa Rica
So I have a '93 HDJ80 in Costa Rica. I was on a long journey over last 3 days way down in the Southern Pacific area (Zancudo, Pavones, etc.) Ran a bunch of back roads and trails. All unpaved and many with a rocky surface that jiggles the car endlessly. After I got back to pavement I noted a new noise that was tied to engine RPM and go louder with load/boost. It sounded like a classic exhaust leak so I just ran the 2+ hours back to my house.
Now looking under rig I see no leaks in exhaust system but after backtracking all the way to the exhaust manifold I now see that it looks like it is leaking at a joint in the exhaust manifold. I can't see the manifold very well due to the turbo but I'm thinking this is definitely the leak even though I can't detect it at idle with my fingers near it just trying to feel for exhaust escaping.
So I was wondering if the forum had experience (searches didn't get me much) on the 1HDT exhaust manifold leaking and how to fix? It looks like there is joint but I can't imagine why it would be separate pieces?
And I may have to drive the truck several hundred km before I can get this fixed. I don't think a bit of leaking exhaust is too big of a deal but this is before the turbo and maybe will get worse quickly due to high pressure?
Any thoughts from the braintrust. Thank you!
And one glamor shot from the trip just for fun.
So I just found these pictures for a manifold on ebay but it only covers 4 cylinders and I see the joint. I guess it is a two part manifold. Some kind of seal between these and I guess that is what has failed.
Well, I'm answering my own questions with more digging. Funny thing is I started using google instead of forum search but ended up finding links back in the forum!
I think I see how this works now. Looks like I will need several rings/seals.
It comes apart but be prepared to hammer it and curse at it for several hours.
I'd order manifold/turbo gaskets, studs and nuts while you're in there. It's under $100 for everything.
Edit: You're fine driving it for a while. Turbo might not have all the chooch it did before depending on the size of the leak though.
Well lets take a step back. I can't hear or feel a leak there when at idle but of course no pressure. I was keyed in on this due to the fresh looking black "soot" on this joint. Would you assume this is the leak that is loud and clear at load/boost when driving?
And then do you think it is OK to put several hundred km on it as is before it gets fixed?
So just FYI the inner rubber o rings are designed to push the metal rings out to give a good seal, but they do wear out/break down due to heat. I would suggest taking the new rubber orings to a industrial seal type shop and getting them to supply some special viton style seals which will handle the heat a lot better. I can’t remember exactly what I used, but they were very special industrial seals with a much higher heat rating that will last a lot longer than the Toyota orings.
I would be ok with driving with a leaky header for a while…
Done a couple of these. The parts to repair are available and the manifolds themselves are still available.
Thank you for info. I can't even imagine how hard/impossible it would be to get custom high temp seals made in Costa Rica. At least Toyota OEM parts are attainable. I assume OEM seals have been working OK for almost 30 years so I'm probably going to stick with that.
