HDJ 81: Leaky Injection Pump
mot
'SUP guys (and gals)?
It's been a hot minute, but my HDJ81 has been leaking (dripping) fuel.
My mechanic buddy has identified that the drip is coming from the location in the pic that I am going to upload in my next post.
Upon doing some research the said part appears to be no longer available (at least from Toyota, anyway).
It's been less than 5 years since I had a local "diesel shop" "rebuild" it and I do not trust them, since the original part lasted over 25 years.
Anyway, my questions are:
1) Is the injection pump on 1HD-T ('90) so unique that only a Toyota shop could rebuild it? (Does Mr. T have a rebuild it of sort?)
2) Any reputable diesel shop could rebuild it? (I'm willing to ship it, CONUS preferred, but willing to ship internationally, if needs be)
3) Should I just buy an already rebuilt unit (core needed or otherwise)? If so, any advice on where?
TIA in advance for any input!
Mot
This is the offending part, I was told.
Mot
The injection system on the 1HD-T is largely similar to the Bosch system used on the 12V Cummins 6BT engine (I believe Denso licensed the design from Bosch), so there are quite a few diesel injection shops around the US that are well qualified to work on the pump. DFIS in Portland, OR has done quite a few Toyota injection pump and injector rebuilds, including a complete rebuild on my brother's HDJ81 IP and injectors. They do excellent work and are very knowledgeable regarding these older diesel fuel systems.
That valve looks like it may be removable while the pump is still assembled and installed. If there is enough access to reach it and you can confirm that its the cause of the leak, you might try replacing the O-rings first. They will definitely be available.
If you do end up needing to rebuild the pump, Diamond Diesel in Oakland, Ca. did mine and they were awesome to work with.
Mot
@AirheadNut is correct. The VE pump is a Bosch design that was licensed to Toyota / Denso for manufacture.
1) No, Toyota (at least Toyota U.S.) is not the right place to go for parts or service.
2) Yes, any Bosch certified diesel shop can rebuild the pump.
3) No. Just like buying a "rebuilt" engine, you are relying on second hand information that the shop did their job correctly.
Personally, I have had a few pumps rebuilt, and I will only ever use one guy. That's Giles @ Performance Diesel Injection in Canada.
He (probably) doubled the torque in my 1981 VW Turbo Diesel, and it's absolutely the single best mod I've ever done to a car.
That being said, I would drive it to your closest Bosch Diesel shop, and have them check it out. If it's just that valve that's a problem, and the truck is otherwise running properly, I would expect they can likely get their hands on the valve (if they don't have it in stock). Bear in mind, I have no idea what said valve does, and whether removal and re-install is as simple as unscrewing it and screwing a new one in. They can tell you that.
I am happy to turn my own wrenches on just about anything, but automatic transmissions and diesel injection pumps are filled with unicorn tears and leprechaun piss as far as I'm concerned.
Remember, the IDI diesel injection pump is your ECU, ignition, fuel pump, etc, all rolled into one. It's very robust, but also very precise.
In most countries where diesel landcruisers were sold, Toyota send all the pumps that need repair to fuel injection specialists.
In Australia, its unheard of to have a fuel injection shop that will not tackle any job. Fuel injection pumps have 2 basic designs, rotary and inline and each of these types work the same way. An old guy that used to do work for me (now retired) said that when a shop was baffled by a pump they had not repaired before, they call another friendly injection shop and get advice or send out the part of the job they cant do.
The only time I ever heard of an injection pump that couldn't be repaired by a locaql shop, was on the KZJ9* where Toyota sent faulty pumps back to Denso in Japan and the customer would be given a Denso rebuilt pump. But now local shops have worked out the electronics.
Try putting the part number into google. Its shows ebayers selling it for under a hundred USD. Toyota dont keep many parts for vehicles once they are 10 years old, but other shops do. Fuel pump parts are generally available for decades after the pump went out of production.
The parts diagrams can be confusing at times because they often use the same initial code number for completely different parts. If you look closely, the code number "22180" has more than one part number. The 22180 on this section relates to either no.1 or no.2 as I've circled in the below photo. These two parts have about 6 different part numbers depending on which year/country your vehicle is but all start with the code 22180-#####. Part no.1 is at the front of the pump and is the case pressure regulator. Part no.2 is at the back of the pump and is the dashpot. Toyota/denso list them both as a "regulator/valve" hence why they both start with the code number 22180-#####.
Thank you for chiming in, and for the info!
I am gonna be taking off to Japan in a week, so I may just have my mechanic and send it up to Portland, unless I can get the piece(s) I need to fix this particular problem which may (or may not) require a whole rebuild.
Thanks again!
Mot
Thanks!
My buddy told me that the offending part(s) in question seemed easily accessible (without removing the whole assy.
So, I am going to to try to get the o rings from a local Toyota dealer and give that a whirl.
Thanks again!
Mot
Thanks, Rosco!
After reading the post after yours, by KiwiDingo, Imma try to identify, or at least narrow down the exact part(s) that would be for my truck.
I imagined that parts required for rebuilding these pumps would not be too difficult to source. But, I guess identifying exactly which parts would have to be carefully studied/researched before throwing money at it.
Thanks again, hope all is well!
Mot
Thanks, Diego!
I am going to do a little more/better researching, both on the diagram, as well as on Google and see if I can get the exact part number of the offending part(s).
As I said above, I am going to try the least expensive option of getting them o rings first, and see if that will do the trick this time.
Thanks again, you guys are all so amazing!
Cheers!
Mot
You can see 751 on the side of this 1HZ pump. Any parts from a pump with the same number as yours are the same. Im not sure about the 1HD T pumps, but the 1HZ probably has about 10 varieties.
The long number that begins with 096000 is denso part number which will also help you identify your pump for parts via Denso dealer
There's several pump variants for HD-T too.
Ideally, injectors should also be ordered to match the pump
Ahhh, that makes sense.
Thanks again, Rosco!
I believe I need 22180-17150 (The one with a pic earlier that I had posted above was "-56351")
My brief search has yielded very little results, but sent an e-mail inquiry to one vendor.
LMK if any of you have better luck than me!
Thank you again to all of you for your valuable inputs!
I have always wondered how hard it is to take apart and change all the gaskets and seals.
I've read thru the injection pump manuals and it doesn't seem that hard to take apart and put back together I've uploaded some service manuals for your viewing pleasure
anyone here attempted a DIY Reseal?
looks like there are kits available and there quite affordable
Its old and all the rubber is nearing the end of its service life. If one o-ring is going, more will follow suit. It'd be a shame for another leak to arrise shortly.
Consider having your mechanic pull the IP and send it to get rebuilt. Another rebuilder option is Landcruiser Specialist in Austin. Dave Martin in Bozeman at Back40 could recommend a shop.
With the pump its probably wise to service your injectors, which is a whole other process to navigate. How close are you to a 100k mile timing belt/water pump replacement? Could do a good reset all at once.
