Hdft Engine and Dash harness (1 Viewer)
Norway
I live in Norway and have been restoring a HDJ80 for some time now. Just before the summer the engine wiring started to smoke so I quickly turned everything off and took the terminal from the battery. Noticed then as a stripped the wiring the some had melt som I need a new one.
When I then looked inside the dash with a multimeter connected to the ground on the ignition (which I new was at fault) I checked every connector on the other side and got a signal. My conclusion is that there are multipul cable that have melted and gives of a signal.
Therefor I am at the point where I do think that I need two sets of wiring harnesses. One for the engine bay and the other from under tha dash that goes to the ignition connector.
Anybody that has one?
As I have started a new and timeconsuming job I am at the point where I am considering selling the car, and I am obviously open for export.
It's very unlikely that you'll find one from anyone in the U.S., as we only got the gas engine models here. You might find success from someone in Australia, but it will be a RHD, of course. If you're interested in selling, I would advise putting an ad in the classified section with a full description and lots of pictures. (and a price, of course) Good luck to you!
