Hawk LTS Pads on 2017
Denver
Appreciate the feedback on fitment of Hawk LTS front pads (HB589Y.704). I’m currently running DBA T3 4000 rotors with DBA SD pads and looking to change out pads. Contacted BuyBrakes and their tech support told me the LTS pads are not compatible even though Hawk website says they are. I also know many in forum are running the LTS pads on their 200’s but then if I recall right the rotor size changed in 2016+ models? So looking for input on fitment for a 2017. Otherwise I’ll go to OE pads or back to the DBA’s. Interesting the only place I can find which sell the SD pads is Slee, where I purchased current set. All other retailers sell either the SP or XP pads. Not sure if the SD and SP are the same (different color boxes)? Thanks for any feedback!
Any pad that works in 08-15 will work in 16-22. The rotor got a bit larger and the caliper moved outward as a result but pad shape, mounting, thickness, and size are all the same.
Excellent info! How do you like them? Any comparisons? Like I mentioned I’m currently using DBA SD pads but hoping for a little more bite and longevity. Do the OE shims work with the LTS pads? Thanks again!
I like the braking performance, they grab hard compared to the Bosch ceramic that I had in there.
The negative is they are very noisy/squeaky when wet or dusty.
The OE shims fit, I used the OEs and binned the provided shims
