I bit the bullet and decided to buy a Harrop E-locker. I decided to do some of the labor myself and pull the third member and ship it to Ken at gearinstalls.com. I've never pulled a third before, I'm hoping the forum could help me along the way.
I have the third out and ready to ship. I had a stud come out with the nut on one of the diff studs. Is there a torque spec to use to install a new stud? Should I use lock tight?
I have a new diff gasket on the way. Should I use gasket or sealant?
Is there a trick to put the axles back in, or will it be pretty obvious?
What would be a good wire to use for an ignition hot source?
Thanks in advance and I'll keep thread updated through process.
