I have 3 hardtops. The "glazing" has worn off and all have a rough almost pebbley texture. The fibers are not showing through. They are not cracked or chipped. Are these restorable? Thanks
What kind of money did it take to make it all pretty again. Yours looks sweetThat sounds like what mine looked like after it was blasted. Scary rough. The body shop put a lot of time into it, and it turned out beautiful. I dont know exactly what he did, but I think most shops that have repaired fiberglass cars could handle it. I wish I had a picture of it prior to going to the body shop. It had holes, gouges, etc.
I'd take it to a boat shop and have them reglaze it.
Or it you're on a budget, fill and paint. I painted mine, but it was in decent shape. It only had a small hole in it which some body filler easily took care of. If I get access to a good compressor, I'll sand it all the way down and repaint it. Some of the POs paint was poorly applied and cracking.
I've done a lot of smaller scale work in fiberglass, and it wouldn't be that hard to DIY a repair with resin if it needs major work. If the shape is there, anything can be repaired in glass.
