Been half-heartedly chasing this issue for awhile, but now I've had it! Gotta get this issue fixed. Broke out the FSM, bought a fuel pressure gauge set, and went to work.
Started with pulling the cold start injector (FSM, pages FI-52-53) I cleaned it up not long ago, but figured I would make sure...
1. Resistance at 3.8 ohms (2-4 ohms spec'd.)
2. Spray pattern even and good.
3. I noticed that when loosening the CSI, there was no pressure being evacuated... Not a good sign, I think.
Moved to FSM pages FI-47-49 (following line by line):
1. FI-48(k) tests at 44psi (37-46 spec'd) (fuel pressure with jumper in place, gauge installed directly on the fuel rail)
2. FI-48(o) tests at 46psi (37-46 spec'd) fuel pressure @ idle
3. FI-49(q) tests at 40 psi (33-37 spec'd)
4. FI-49(r) fuel pressure should remain greater than 21psi for a minumum of 5 minutes.
Here lies my question. Fuel pressure @ idle with vacuum hose disconnected from FPR is high; when the engine is shut off, the pressure immediately drops to ZERO. I have no experience with FI systems, so I'm asking for guidance and knowledge, as my searches through the site have not netted me a definitave firm answer in my mind - does this indicate the FPR and/or the FPD need replacing? FSM says check fuel pump, pressure regulator, and injectors. I figure that some guru here (@jonheld, perhaps? ) would be able to give me some insight based on their experience. Knowing that I have a near-30 year old rig, I would like to (but my wallet would not) rejuvenate the fuel injectors as well, but baby steps...
Thank you in advance for the help.
