Happy Rock Warrior Day
I wonder how much longer I’m going to have to hold on to my Rock Warriors with old (still decent shape center caps) and new center caps? Seems like pricing was high now it’s tapered off some.
Ordered Friday. Got this today.
I painted mine black and applied TRD decals from TVD.
Who’s got two thumbs, four Rock Warriors, four new center caps, TPMS sensors, twenty splined lug nuts and forty-eight new Torx fasteners on the way?
Hint: The same dude that just ordered his 285/75/17 Ridge Grapplers.
We’re gonna need pics.
well these are the new additions, before I had a chance to take them apart and give them a good cleaning... should have lugs tomorrow and tires in by Wednesday. Hopefully the Torx fasteners get here quickly. The new caps and sensors are already here.
Has anyone ordered the rings separately? Please share part number or link if possible
PTR45-35110
Paging @gaijin for an RCTIP on 285/75/17 load rating C Ridge Grapplers on a 2013 TLC that weighs 7260lbs with driver. TIA!
If you mean the LT285/75R17 C 117/114Q tires on your 2013 LC200, then:
The RCTIP for those LT285/75R17 C 117/114Q tires on your LC200 is 37psi F/R.
As with all my RCTIP recommendations, that pressure is good up to the GVWR of your LC200 - 7385lbs.
HTH
HTH
how much would the RCTIP psi for Nitto Ridge Grappler LT285/75/17 E 121/118Q
Also 37PSI
From @gaijin elsewhere (I use same tjre)..
“The Recommended Cold Tire Inflation Pressure for the LT285/75R17 E 121/118Q Nitto Ridge Grapplers on your 2017 LC200 is confirmed as 37psi F/R.
HTH”
Not so happy rock warrior day. Bad rubbing on the front tires/back mud flap fastener. I guess the 1.25” spacers must be the problem. Despite dozens of posts no clear answer on if they will fit without spacers because there are no 1” or .75” spacers to be found anywhere. Incredibly frustrated. They look great though.
What about KDSS rub? There are reports of RG rubbing in that size on KDSS fairly badly.
They do look good. :rofl:
I just bought a set of same size, I have heard others not having any rub. May be the spacer is too much?
