Happy New BJ74 owner
Photo missing
Do not know what happened to the picture that was here?
Shackle reversal DONE; Here's pictures!
Tonight we did the shackle reversal-(pictures tomorrow); it raised the front end exactly 2" higher to level out the Old Man Emu lift. We used Proffitt's Cruiser's custom spring hangers ($90) and everything went great! I did combine/move the brackets around for the front cable locker so as to give some slack where needed, and make any taughtness or tension go away, and get smoother action. We moved the axle forward 1.5", and gained the needed clearance for the 35" wheels. I recommend this as the right way to get the needed room/lift. Handles and rides like a new car.
The snorkel install was not a big deal either, hardest part is lining up the 4 screws and holes on the side of truck, as the templates are not correct in the positioning of these screws/holes so we had to keep making them a bit larger to align everything, and use fender washers to cover the holes when done and reinstalling snorkel. All in all both mods were necessary to me, and not hard at all, but these guys @ Proffitt's have been at it way longer than myself, and are PRO's.
Better photos
I wanted to put these pictures here as they show better how truck sits now with shackle reversal/axle relocated 1.5" forward. The rig handles very nicely, and no rubbing anywhere, front or back.
To regear or not is next, then speedo correction, sliders powdercoated, exhuast 3 " straight pipes, body work, speedi-liner, and paint as needed...
Wanted to say Hi; Bought/Buying a sweet BJ74 with 13bt, locked and loaded! 60,000 original miles.
Now Selling my 1988 FJ62 expedition truck and now building up the 74 with; Spring over axle lift, and 4.56 gears?, repaint same gray color and repaint roof, bigger exhuast size?, gauges for pyro, and boost. Snorkel,pre-cleaner, hot water shower, compressor, BFG Mud 35's, Bull bar, swing away rear bumper, sliders, and building trailer to pull/sleep.
Need advice help; on the 24/12 volt converter;it's not hooked up and looks like wires were cut, I need to know how to check if it's working/works< as stereo, cigarette lighter needs to work soon...may be shot?
Also, any tips for tuning, and gearing if you've run 35's with yours? SOA? Has OME heavy/medium now... want more...Going shackle reversal also, and going with wheel flares.
Running different blends of diesel, wvo, kerosene, and LOVE IT!
Thanks, this truck is so frickin' cool! I will not go back to gas, and also going for a troopy soon too! Addicted to 70's!
hey good stuff mate, looks like we have the exact same plan, i just brought a 73
gonna do a soa with 60 series diffs so i can get the diffs ready with perches and high steer, then do the swap one weekend, seeing it is my daily driver,
then bigger exaust and 35's
then finaly paint it black,
keep me posted on the build mate.
Dave:steer:
Awesome rig man...and nice website
So , how are the benefits of the shackle reversal installation?
shackle reversal
First and foremost the ride is way smoother now. The bumps ane no longer jarring and the truck does not wander anymore, due to better caster angles. Moving the axle forward also helps a lot, and the ride is like a new vehicle. I recommend doing it, and it also lifted the front end 2" to even up the raked look after the OME lift was done.
Whats GAS? welcome to the real world of diesel TORQUE. on My LJ77 and TROOPY I have a 3inch straight through (with a muffler following the original path) works cool. putting it out under the drivers door will drive you mad withthe noise. On MY HYbrid 13BT/14Bt, boost and pyro gauges are compulsory to prevent blowing engines up when you least want them to. I did that so I know. I run 8/39 (4.875) DIFFS and on 35's the speedo is spot on. On the track the gearing is ok LO 3rd is the most flexible gear and it will pull it ok. Remember 13B-T's run hot. I raised my TROOP only to dropit back down again I did not like the way it swayed around. I will trade the extra winching any day than risk an accident.
Get rid of the converter and start again with your own calculations before buying one.
Crikey were you going to put all that kit in such a tiny wagon - inspector gadget 4x4 when finished.
12/24 converter installed
Got a chance to have the converter wired up, and also an outlet for both 24 volts plus 12 volts installed in rear cargo area. Fridge is hardwired with 24volts now-always hot, and cigarette lighter has 12 volts. The Samlex SDC 23 mounted above glove box hidden and out of sight. Everything works great.
Next the bumpers get fabricated, and powder-coated, to match the sliders now waiting to go on.
PTO to ARB bull bar, and custom rear bumper fabricated/mounted
The past few days this week began the building of the rear bumper, and also fitting a new ARB bullbar to the factory PTO winch up front. I wanted to keep the factory optional PTO winch as a cool, original item, and becuase i am familiar with them from my military days, and I like them, and trust them.
At this time too, any rust issues are being cut out and replaced with new metal. The lower body line down will get E-Z liner(SpeediLiner) sprayed for rock/rust protection too. Fender Duraflares will go on soon. The custom sliders and both custom bumpers are getting powder coated, and then back on after a bigger exhaust is done, and paint is done.
Here' pictures of work being done, bumpers, and PTO.
The rear bumper was made to have a "factory" looking step built in that will serve as a small shelf as well as step, when camping, and for a MSR stove to cook, etc.
Retained the ability to use the small left-side rear door without any obstacles or moving anything to open the door, like for dog, or fridge needs. Very happy with the work, and custom builds by Jeremiah Proffitt @ Proffitt's Cruiser's.
