- Joined
- Sep 26, 2003
- Threads
- 117
- Messages
- 11,199
- Location
- Lancaster, Ohio, USA
- Website
- www.tlcperformance.com
Thanks for the reply sadam! We don't have that particular model over here, but others similar, or maybe the same just with a different name. I do have a pair of those calipers buried somewhere out in the shop. Any pics or info on how you adapted them to your rear axle would be appreciated, maybe in a different thread so as not to hijack Tom's thread.
Hijack on! All Subie frt p-brake calipers are the same AFAIK for ~85-90. They are slightly larger than Cruiser rear brake calipers (48mm vs 54mm), so should be a good fit. They are cheap from Rockauto, a pair of loaded reman calipers for $60. FWIW Sadam's 70 has the same rear OEM brake setup as FJ60, which means a different adapter bracket than most FJ40.
I've got parts on the way so I'm already thinking about reassembly (even though I haven't got to the bottom of the failure yet)...
Question 1: Has anybody got any idea why Toyota has this thin shim here under the thick washer?
I can't see what purpose it serves and I'm thinking of leaving it out (because it is paper-thin and on the verge of disintegrating anyway)
Nope. It's always there from the factory and serves no dimensionally useful shimming purpose in that location. Initially I assumed it was a spare for someplace else in the t-case, but it's not. There is no shim in the case like it. I discard it now, as it is simply another failure point that can lose crush and allow the drum to rock on the shaft spline.
Again, I used to do the same thing, but now the silicon is applied between the d-shaft yoke and the transfer output flage/drum. This keeps the stinky 90wt from slinging outward off the spinning drum, staining the bottom of the customer's Cruiser.And while I'm thinking of this area, I've usually used silicon sealant on the splines to try and stop oil from flowing between the male and female splines (and I believe this is common practice for others here to do this too)...
But this time around.... I'm having second thoughts about the logic of doing it..
So the second question is ... Anybody see any problem with omitting the silicone sealant this time?
