Well, I spent about 4.5 hours today working on the front axle service. I'm replacing the trunion bearings, wheel bearings, and all the associated seals. I'm also replacing all of the TRE's.
I experienced the wonderful "birfield soup" on both sides, but moreso on the right side(USDS). I got the driver's side completely stripped down, cleaned up and ready to go back together. I then installed the new trunion bearing races and inner axle seal. I'm doing the work on a lift at a friend's shop and his parts washer has been a god send. I started to tear down the passenger side and got that birf apart and cleaned up. I still have to take the knuckle off the passenger side and clean it up, but otherwise the front end is ready to go back together. I wasted about 45 minutes trying to figure out how to put the balls back in the birf once I had repacked it with grease and felt like a COMPLETE MORON once I figured out you can put them in from the outside of the cage(as opposed to aligning the inner race and cage and birf just right so they drop in). So I've got 3.5 hours of actual work in place and I think I have another 2-3 to go. I'm very pleased as this is my first time touching birfs, and the mechanic's book for estimating times says 8.1 hours for the job.
I'm using Mobil 1 Synthetic grease. I looked at every store in town and no one carried "Molybdenum Disulphide Lithium Base Grease" so I did a search on here and read that a couple people are using the Mobil 1 grease. Hopefully this will be ok. I'm planning to run Mobil 1 75w90 in the diff, is there anything I need to do in preparation for this?
Thanks
Ary
Thanks
Ary
