- Thread starter
- #281
A stout bed???
Edit: I googled it. I see what you mean. Would look cool, but probably unobtaininum.
for sure...
A stout bed???
I got lucky in that the short shaft was long enough to reach the far side gear in the diff to get the housing aligned right and at the correct length. time to disassemble and repack the hubs, gasoline douche the housing, paint and reassemble using new hub studs and nuts and outer axle seals. so the only thing still up in the air, is do I hang it SOA or keep it undersprung? the SOA on my flat rear springs will net about 3 more inches than I have now...without doing the front, there will be a 2" stinkbeatle(yoko) stance...not sure that I would h8 that.....By tackling this job at home, I saved between 250 and 400 bucks- the range that I was quoted to narrow the housing by Fearless Gear in Fresno. that price was if I brought them all the parts stripped and cleaned, just to section and weld one end. I figured by the time I got there, that it wasn't a great big mystery, and that if certain thing were taken into account, there was no way to mess it up beyond any chance of repair. heck, if I didn't get it straight and had to take it to the gear grinders, I'd be no worse for wear...This forum was of GREAT help in doing this. Several threads went over the finer points of axle narrowing and had some nice pics to illustrate the process. I think seeing Fast Eddies and LCwizards contributions were the greatest help in this area. next will be spring perch mock-up under the old wagon...new WMS# is 59 3/4"the used axle was 700 plus about 30 in gas...the AM axle shaft is going to be less than but close to 250 shipped. spring perches and u bolts, axle studs and nuts, axle oil seals, add another 200. front spacers(for now)80 bucks...totaling out at about 1400 bones. yikes. lets keep that quiet....
if I have to relieve the gusset for the center bolt of the spring, it will not be an issue...this may happen w/in the week...Grind the fxxx out them ? That's how you use condoms twice, you use them once then turn them inside out and shake the fxxx out of them![]()
and
full floater mounted, spacers and new to me tires/rims-295/16s. need to replace 2 ubolts, tack on the receiver ends for the sway bar links to the brackets on the axle housing. got the nitro cut to fit axle shaft installed. second torquing, and it's time to test my housing weld. then I just need to build the controller and figure out and ebrake cable coupler deal....pics to follow
