- Joined
- Dec 10, 2003
- Threads
- 36
- Messages
- 497
Royal Purple 75w-90 with a friction modifier. I don't change often so I use synthetic.
75W-90 GL4
Awesome! How much does the H55f take? and would you use that same chevron 75W-90 in the diffs as well?AutoZone (thus easy to get) has a new addition to the gear oil shelves:
Chevron Delo SynGear XDM 75W-90. Has GL-4 and MT-1 certs right on the bottle. Also significantly cheaper than the Mobil1 75w-90 which is the other readily available alternative.
http://www.autozone.com/greases-and...thetic-gear-oil-sae-75w-90-32-oz-/443149_0_0/
Perfect, thanks!I think 10 litres will do the gearbox/transfer case and 1 diff. If yours is a KO85 on the aluminium plate, it means you have an LSD in the rear.
If the LSD is still working ,you should use LSD oil. If not, ,normal gear oil will suffice, same as the gearbox.
