When we use a GL-5 product in a transmission that requires GL-4, we normally find 2 to 4 times as much copper in the used oil as we would with a GL-4 product. Eventually the synchronizers wear to the point that they no longer make contact with the other half of the cone, bottoming out before stopping the opposing gear.
Just remember that GL-4 and GL-5 are gear oil ratings, not transmission oil ratings. Transmissions have gears AND synchronizers. These seemingly conflicting requirements must be met differently.
When someone tells you that their GL-5 covers GL-4, remember they are correct as far as EP protection, but that is only half the answer. When they say their Sulfur/Phosphorous additive will not corrode the yellow metals, they are also correct, but if there are enough to meet GL-5 protection, they will slowly peel away your brass synchronizers.
http://www.widman.biz/uploads/Transaxle_oil.pdf
Not from my inspiration .. was taken from website ..
THIS IS THE MOST CORRECT ANSWER , not from my inspiration too , it's my job.
infact the focus is that transmission (gearbox) it's not only gear
cheers
