After digging around and playing with my transmission lately; installing a stainless braided clutch line, properly bleeding, setting pedal height per the FSM, making sure everything else was in order, the mild stop/notch I hit when shifting into 2nd and 3rd (consistently into 3rd, upshift or downshift; sporadically into 2nd) remained. I finally determined that the synchro rings are worn just enough to still work, but not as well as they should be. The symptoms point to the inner surface being worn so they can't grip the "cone" portion of the synchro hub enough to allow for a good clean shift, but when the slightest pressure from the shift collar is applied, they line up and the collar is able to pop into place and complete the shift. On a few drives around town I experimented with double clutching and the shifts ended up smooth as silk. This further confirmed my deduction that the synchro rings are worn. Also of note: double clutching a truck transmission is a workout my left knee would rather pass on. Next summer, time allowing, I'd like to pull the tranny and install new synchro rings. It only has maybe 15K after a rebuild, but no idea how many miles it had on it by the time it was done, and the synchro rings are a reusable part that were obviously good at that time (they worked beautifully through all gears throughout this last summer since I had the swap done at the beginning of May; just started showing the wear maybe around late August IIRC). Plus I had bought the tranny back in 2010 and it sat in my shop until earlier this year when I could finally get the swap done.
That being said, I noticed that all three synchro rings are the same part number (33368-20012) from Toyota and are reasonably priced, so I plan to replace all three (no issues shifting into 5th gear, but figured I'd do it while I'm in there. The Land Cruiser mantra), and was curious if at only 15K miles I should even bother with the bearings. I know when the rebuild was done it got new bearings, so unless a particular bearing is a non-reusable part I'm assuming I shouldn't need to bother.
My other question is, are there upgraded longer-lasting synchro rings even available for the H55F? I've seen there are for many domestic manuals, but searching didn't land me with any results for the H55F. Found some non OEM that were cheaper, but if they're not an actual upgraded part, OEM all the way for me.
