H41 Counter Shaft (Layshaft) number
Japan
I have serched many threads but i could not find the answer. Can you help me?
I have counter shaft from JDM FJ60 1981 2F , H41 transmission. parts no is 33411-60050
I want to put this shaft to 1989 HJ60 STD H41 transmission.
Later H41 transmission's Counter shaft no is 33411-60060
What the difference between these shafts?
Can I put this shaft to later H41 transmission?
Thank you
I have never found two Toyota parts with two different part numbers to be identical parts. The difference might be small, but for a transmission countershaft, any difference would be a deal breaker. It has to be exactly the same.
While that later countershaft -might- work, personally I would never expect it to and wouldn't even consider it as a possibility.
(But maybe it'll work)
It’s mansglish for “the business shaft”
Are you sure about that "1989 HJ60 H41"? Is this a typo? I don't think there were H41's that late. The part number you have for your "1989 H41" doesn't match my list of countershaft part numbers, your first countershaft part number does though.
H41
80-82 33411-60050 (BJ60/FJ60)
H42
82-85 33411-60051 (FJ60)
H55
82-85 33421-36040 (BJ61/HJ60/FJ62)
H42
84-85 33411-60060 (BJ61 4F)
H55
85-90 33421-60050 (HJ61)
85-90 33421-60060 (BJ61/HJ60/FJ62)
Thank you
I am sure , my HJ60 1989 STD ( model HJ60RG-KRG) has H41
Please see this
and it shows the number of newer counter shaft is
33411-60060 Gear, Counter [08.1987 - 01.1990] BJ60,FJ62,HJ60..4F
Thank you
