Wanted H151F to 1FZ-FE bellhousing
Socal
I'm looking for a bellhousing for a 1FZ-FE to H151F manual conversion, along with a 300mm flywheel and any other parts needed for a conversion.
Thanks
Dale
Thanks, when I've looked nothing came up. I'll try changing my search
The flywheel is the tricky one. I bought mine new from partsouq but it cost an arm and a leg to get it here...
I had good luck with some Aussie guys here on mud for my factory sub tank install. Lots of guys here know people that are wrecking trucks.
Trick with the conversion is budget. You can buy everything new if you want, including the bell housing from partsouq.
Do you happen to have contact info you the aussie guys you mentioned?
Do you happen to know the model or VIN for the 80 with manual and 1FZ-FE, so I can look up the Bellhousing?
Thanks
Dale
31111-60302 is the bell housing. You will need dowels and those little rubber vent things on top as well.
I'll have to look in my records for the guys I was talking to...
Thanks, it's awesome how helpful everyone is on this site
No worries, can't find which guy on mud it was I think I deleted the PM chain...
If you need help with finding parts let me know. There are a few of us that have done this. :)
This is the Bellhousing for a 1FZ-FE to H151f?
Have you used it, how did you pick this one?
When I search I can find several different ones.
Thanks
Thanks
The original p/n is 31111-60250 but is updated to 31111-60302.
I'm sure cruiser outfitters or specterOffroad can help you get parts. I got my dual Toyota filler neck from SpecterOffroad.
