Ive always appreciated a good build thread with details on the parts used. I'll try to do my part in documenting my build.
2006 GX470 bought with just over 115K miles, really great shape and a good service record. Seems it spent most of its life in Beverly Hills and Newport Beach CA, but I found it up in Southern OR at a Nissan dealer! I bought it over the phone and flew up the following week to pick it up! I was not disappointed especially considering I was planning on building it up. Below is a list of mods that are done and mods on the to do list. Ill document individual parts of the build in later posts.
Here is where it is today:
Cheers!
- Floor Mats - Weathertech all the way around
- Rear Hitch - Southern Style Offroad – “The lightweight hitch”
- Stereo - Phoenix Android.
- Still not working perfect, certainly NOT plug and play!
- Muffler - Magnaflow
- Air Filter – K&N drop in
- Timing belt and All fluids changed
- Front Brakes
- Power Stop Z23-976, Z23 Evolution Sport Carbon-Fiber Ceramic Front Brake Pads
- Power Stop JBR975XPR Extreme Performance Drilled and Slotted Front Rotor
- Rear Brakes
- Power Stop Z23-606, Z23 Evolution Sport Carbon-Fiber Ceramic Rear Brake Pads
- Power Stop JBR971XPR Extreme Performance Drilled and Slotted Rear Rotor
- Front Axel Shafts - CARDONE 665235HD
- Spindle Inner seals
- Tires - Bridgestone Dueler AT Revo 3 @ 275/65 18
- Rims - Fuel Tactic D630 Model D63018908350 @ 18x9, 1mm offset, 5" BS
- Front Suspension -
- Fox 2.5" Factory Series Coilovers, DSC and external reservoirs (Fox FRS 883-06-130)
- Total Chaos UCA (TCS 96504)
- Wheelers bump stops
- Rear Suspension -
- Fox 2.5 Factory Series Rear shocks DSC and external reservoirs (FOX FRS 883-26-004)
- OME 2" Coils (OME2895)
- Spring converter from Apache off road
- Sway Bar End Links - from Dobinsons
- Battery Tie Down - Off Grid Engineering Tiedown with J-Hook (8" and 10")
- Rubber Splash Guards (behind front suspension) - Rad Rubber Designs (LEXUS GX470 & GX460/PRADO)
- Diff Drop
- Skid Plates - 4 piece from ARB (for Prado 120)
- Fix Phoenix Audio (Heat/Air only works on Auto mode)
- add front camera
- Sliders - Not sure which ones yet.
- LED lights and hyper blink modification
- Tint the windows darker
- Front wheel bearings
- Amps, sub, speakers
- Finally make time to go play with it!
Cheers!
