WTITW
- Joined
- Feb 13, 2020
- Threads
- 90
- Messages
- 725
- Location
- Chandler, AZ
- Website
- www.wastingtimeinthewoods.com
I wanted to start a hub to fender measurements thread for reference for various lifts. I couldn't find one on the 150 platform. If enough of us contribute to this it could be a great reference for future owners wanting to modify their suspension. The standard (though not completely accurate) method is to measure from the center of the hub to the outside edge of the fender lip. This needs to be done when the truck is on level ground both front to back and side to side, otherwise the truck will lean and measurements won't be accurate. To make it easier I measure from the lower lip of my rim to the fender and then subtract the rim radius. That way you have something to hook the tape measure onto and can be a bit more accurate. I'll go first, template at the bottom.
Truck:
2010 GX Premium
Extra weight - None
Lift:
IronMan FCP
2.5" front springs (0 Preload at factory setting)
2" rear (Toyo 056B)
Ironman Airbag Delete kit - (RR set to zero, LR 1/2" thread showing)
After Lift Measurements:
Lf 21.75” (net 2.25”)
Rf 21.625 (net 2.375“)
Lr 24.25” (net 3.5“)
Rr 24.25” (net 3.25“)
Truck Pic 265/70/17's
Template:
Truck: (Year and trim)
Extra Weight: (Example - Bumper winch aprox 200lbs)
Lift: Manufacturer, model and settings
(Be sure to mention if you changed default preload, added trim packers/spacers, etc. Mention aprox age if not new)
Measurements (Left and Right are always from the drivers perspective looking forward)
Lf (Left front):
Rf (Right front):
Lr (Left rear):
Rr (Right rear):
Pic! (add your tire size please if you post a pic for reference)
Truck:
2010 GX Premium
Extra weight - None
Lift:
IronMan FCP
2" rear (Toyo 056B)
Template:
Lf (Left front):
Rf (Right front):
Lr (Left rear):
Rr (Right rear):
