on my scangauge 3, i used what they said and 1 is pan,2 is tc. mine is a 2019.
Its really nice - decent fit, easy to install etc. The system doesn't make any sound - very solid - and there is a pretty good amount of space between the top and the floor of the truck bed - which is "nice" for insulation and wires etc - but could be tighter. I think the main point you are making is what do you now do on top of it - you need some rubber up there, etc. I still just lay the stock carpet and carpet protector down and it doesn't fit. Been trying to finalize the dual battery set up first, so been delaying buying something, custom cutting etc. Also think you can just cut up a Husky/Weathertech liner, but then you don't have the lip. Need to have something thick enough to reduce noise on top, but still thin enough to use the slats for the tie downs.Very nice build! How do you like the Victory 4X4 modular floor system? I've been eyeing it for a while but, am worried that it will rattle and stuff will just slide around on the metal surface.
It has these slots that allow for any nut / D-ring combo you can fit. The slots are small, width wise, so you can't put huge bolts in there. They do run up and down the floor, though, so pretty flexible. I think they are big enough to secure everything I need to like a fridge, etc. They provide a lot of hardware, but thinking I will have to search for some longer D-ring connectors or bolts to go with the factory stuff to optimize.Great info, thank you! One more question. Is it designed where you can mount whatever fridge slides you choose to it or are you limited to the Victory fridge slides?
Thanks again! They are having a sale so, I went ahead and placed an order. I really appreciate the information.It has these slots that allow for any nut / D-ring combo you can fit. The slots are small, width wise, so you can't put huge bolts in there. They do run up and down the floor, though, so pretty flexible. I think they are big enough to secure everything I need to like a fridge, etc. They provide a lot of hardware, but thinking I will have to search for some longer D-ring connectors or bolts to go with the factory stuff to optimize.
