Hi guys I'm recently purchased a 97 collectors edition and have been fixing surprises daily since. I am doing all the work myself and learning as I go. I randomly checked the oil cap yesterday and found an interesting white substance under it and the ledge right below it in the hole.
Background.
After driving it off from the previous owner it over heated 30 min into the drive. I found tons of stop leak clogging everything related to cooling. I changed the radiator, thermostat, water pump and a few hoses. On top of that I flushed the heater cores, block and radiator two days in a row earlier this week. I alternated between water hose and compressed air. A great deal of stop leak came out both times and I plan to do it again once the temp gets over 35 degrees outside.
Good news is that it doesn't over heat anymore, even when pulling a 16ft trailer. Also the front heater finally work, but back is still cold.
A friend suggested the sludge was coolant and a head gasket leak. What are your thoughts? I Don't want to pay a mechanic so I need all the help I can get diagnosing this stuff.
1997, 202,xxx miles.
Your help is greatly appreciated.
Background.
