Spresso: you need to relo the DS O2 cabling! Do this BEFORE you install the header and you'll be much happier!
would somebody post some pics of these installed already!?!?!?!?!?!?
Thanks! I'm right behind you...spent the last 1/2 hour trying to get that forward lower nut/stud out. Naturally it was the one that was REALLY torqued on from the factory...just as I expected...all the others seemed like they weren't tight enough!
I was able to get the heat shield out before removing the exhaust manifold as it really allowed better access to the manifold nuts/studs.
Taking a break before going back out to install the header. Thanks too for the heads-up on the engine mount!
Where did you relocate your cabling to?
Thanks for the updates Spress, sounds like it's going relatively easy. I can only hope the same goes for when I get mine done/started this week hopefully.
I was anxious about this job due to the fact my rig came from a rust belt state and if I snapped/sheared/rounded off any of the nuts or studs the likelihood of having to pull the engine, especially for the limited access nuts/studs, was a very real concern.
You will need PLENTY of tools for this job. And I wouldn't even think about this job as a DIY IIWY if you don't have at least a good 1/2" drive impact (I also used my 3/8" drive impact for a few of the limited space/access nuts/studs).
Have 16-replacedment OEM studs on hand along with, of course, new nuts (along with header gaskets...mine were not reusable...and CAT pipe gaskets) unless you have zero rust on your rig...and even then you can always return unused parts.
Yep those lower DS nuts on the DT's are a biotch to get tight. If they were as rusty as my OEM there really wound not be a way to get the DT headers off sans pulling the engine and cutting the DT pipes out of the way to get full access to the nuts/studs.
Both headers are on...just need to lower the engine, bolt the CAT up and connect the O2 sensors.
OregonLC: Thanks again for the PS and DS O2 sensor heads up...that saved me a bunch of time and cuss'n.
Everything's done except getting the #2 steering shaft reinstalled. For whatever reason...probably corrosion...I can't get the sliding coupler to move down far enough onto the steering shaft. Would SAS solve this?!![]()
So here's what I found: where the shaft meets the coupling next to the firewall, it will only go into a single clock position. If you look on the coupling, there is a slot on the back side (opposite the split) and I think it may be keyed. So to index it, you leave the upper coupling bolt undone (which allows sliding) and you clock it at the rack. Whatever the reason, I had the same problem and this seemed to fix it. I did lube all three splines which helped the sliding action.
I'm back and running. Started with no codes on the first crank! Driving impression: I guess I don't have enough regular seat time in the LC to be a good judge, but it wasn't a huge difference to me with the seat-o-pants meter.
Good to hear you are complete. I'm not expecting much...its probably hard to tell 25hp by seat o'the pants. However I DO notice considerable HP improvement when I go down to sea level
I didn't remove the sliding collar apart of this job...just the 2nd steering shaft. I'm going to start fresh tomorrow morning and figure out why the steering shaft won't go home within the collar. "Close but no cigar"![]()
Were you able to shove the steering shaft up into the coupler to get it off of the splines at the rack end?
