WARNING
If you grease the splines of your driveshafts according to the Factory Service Manual, it MAY create an extreme amount of pressure on your transfer case and axle pinion shaft by acting as a hydraulic ram piston.
The FSM says to pump in grease with a grease gun until it begins to ooze out. For the U-joints it's not a problem. It oozes out very readily.
However, for the splines, at least some vehicles seem to have grease seals that are too good. When you pump in grease with a grease gun, it can't get past the seal and just jacks up the drive shaft so the splines can't slide and get shorter when you go over a bump. Some seals seems to be looser and let some grease squirt by and don't have this issue.
One guy reported actual breakage of the transfer case.
Here's a thread on this some time ago for more background:
https://forum.ih8mud.com/80-series-tech/20022-updated-warning-greasing-rear-drive-shaft.html
When I finally got around to greasing my truck, I found that I had this problem. I could actually see the axle being moved by about 1/8 inch as I pumped the grease gun. The suspension bushings were being compressed. So, I removed the drive shaft to check into it.
Photo 1) The drive shaft between 2 blocks clamped to a 2x4. Pumping the grease gun flexed the 2x4 pretty easily.
(No, I didn't miter saw the drive shaft
Photo 2) After a number of flexes, the blocks slid in spite of the clamping friction. They started out even with the pencil line.
Photo 3) This shows grease oozing out of some pressure relief grooves I filed in the seal. It was jacked against the blocks again, just to see what would happen. Obviously, the filing was done while the 2 pieces were taken apart, not as shown. With a the thin edge of a needle file, I took about a dozen strokes on the inside surface of the seal at several places. I don't know what the right answer is here, but I made a groove at every 2nd spline.
