relatively speaking of course
just took the truck for a test drive. between the new plugs (irridium) two wheel drive mod and the advanced timing (i was previously advanced, but thought I could go a bit more...now at 10-12 BTDC NORMAL, not shorted pin)...i'm a happy man. still no speed daemon but much better. folks had said the steering would be "lite" when running in two wheel drive mode...but I think it's "Just right"....especially with 37" tires. If anyone is interested I will report back the mileage (gps style mileage...granted, I have 37" tires--I am re-geared to 4.88, so kinda like stock gearing)
oh, I also found a trick way of cutting the rear of the front fenders (if needed for more clearance for larger tires). It almost looks stock, but i went from about 2" of gap to a little over 5". I took a bunch of pics, but need some time to post them up.
Kumar
...on to slider trimming, 1" mr gasket spacers, a/c pressure check (all today)
edited to add pics:
*****BEFORE******
****AFTER***** (note that the slider USED to be right at the edge of the old fender line, yes I've trimmed the slider back and 45* wedged it)
and NO the tire does not rub on the plastic fender (trimmed it a bit, and now it's out of the way). If it so happens to rub on the trail, that's why my trusty leatherman is for.
Kumar
Kumar
edited to add pics:
*****BEFORE******
Kumar
