- Thread starter
- #41
I learn something new about my 40 every day. Went out to the POs house this weekend to pickup a bunch of parts he had found. There were the original door stops, and pads for the rollbars, and a set of 4 overload springs etc. But he also had the original front spring hangers. I lined those up with the factory holes on the front of the frame and learned that the center of the front leaf spring eye is set back about 1 1/2" from where it should be. That's probably why the axle bumpers don't line up with the axle and the front diff is pushing the engine and trans off of their mounts!! This is NO BUENO! Definately not road or trail worthy. Also the "shackle reversal" that was done was quite literally a shackle reversal using the original spring mounts from the rear on the front... ALSO NO BUENO! I've seen a MAF SR kit and it is about 3 inches below the frame to provide the correct angle on the springs. Well, long story short I'm going to do a shackle reversal reversal! And for anyone considering doing a SR I think it creates more problems than it solves IMHO. If the springs are mounted correctly AND you get a front driveshaft with longer slip you are on the right path, but I just wish mine had never been messed with!
