Oh, I was thinking you wanted someone to wrench on your cruiser while you surfed!!!
and salt water really does wonders to open wounds caused by wrenching![]()
I've had good and not so good experiences with Harry which is why I've not responded to this thread to date. I had them do my last 'major' service at 180K on the clock (30K service at the dealer). Was told there was a small crack in the large rubber intake hose after the MAF sensor. All the way home after the tune up the engine wanted to stall and did several times! WTF!!! Since I'd picked it up right at closing I couldn't go back. Took a look at it and the entire intake was hanging on by one small piece of rubber! No wonder the engine was stalling. Way to much oxygen!! Yes it's old rubber, but a small crack, NOT! I've been reluctant to go back. Their head mechanic, Mark, is a former Toyota Master Mechanic and they've been great up to this point. I can take parts sourced from Cdan and they'll just charge labor. Harry is a cruiser fanatic and Mark love everything Yota truck, but I was flat out lied to regarding this.
End of this particular story is that I ordered the new intake from Dan, slapped it on in about 5 minutes and all is fine.
Get with Harry at Laguna Viejo Auto. He's got a lifted '94 with ARB bumpers in front.
What does he need done?
Have tools, will travel for $
That rig had me fooled for awhile, I thought it was Rich's (rpfzj80) 80 getting worked on, looks just like it. I guess I should say old 80 since he sold it.
Just to play devils advocate Brent it is possible that they only saw a a crack when they were working near it if they did not remove it as part of the service. When they break down in one of the accordian ridges it is very hard to see unless it is removed.
My intake hose was broken circumfrentially into two pieces as well from the time I bought it I think untill some lady drove into my Cruiser while it was parked without hitting the brakes. It took that much of an impact to jar it loose and throw the CE, stall etc. the on the drive back home. You know how meticulous and anal I am and I missed as well. It is possible it was just missed. My .02
Aside from all this is there anybody in the area that can help me put a lift on my truck? I'm getting OME 3" lift kit from MAF.
I'd go to Harry for that. I don't know if they've got a press for the castor correction bushings tho. Outside of a lift, that's the piece of equipment really needed. The rest guys have done on jack stands in their driveways from everything I've read here.
I have used Amato (ROB) for many issues with all cars. A lift install should be no problem 949-348-8473
I used to take my LX to Laguna Viejo Auto and during that time, Harry did quote me to put a lift on. I think the whole job was quoted at 6 hours labor @ $94/hr. We talked about a variety of options for work split between me/them to get the cost down. I ended up having them install the shocks (2 hours labor), since I thought the bolts were pretty stuck, and I did the springs/castor correction bushings. They (Harry & Co.) do not have a press large enough so I ended taking my arms to the local machine shop around the corned they use and got new bushings installed for $30.
Also, Harry used to be an ARB rep, so he may be able to order parts for you as well. I don't really know any more since I have since moved on to another shop for my repairs.
Hope this helps!
