go through firewall
What is the easiest way to go through the firewall for wires to piaa fog lights? I am thinking of mounting switch on the blank black plate on the right side of steering column.
There are giant rubber grommets you can cut a hole through, run your wire, and seal with RTV on the DS and PS firewalls.
yup on the right side of the engine bay, if you take off that engine cover, there is a rubber grommet that feeds wires right to the driver side under dash area
