In the interest of time I picked up a complete door too. If anyone needs a spare to test with, mine is for sale![]()
This is the fix. I added to my post above showing the location of the screw. Your post gave me the information and confidence to try it. Thanks!A small hole in the middle and a philips screw driver can repair it. I bought a new door so I tore the old one apart.
Do you have any better pics of the mechanism in the center? Trying to figure out what's going on inside of there.Tore apart a glove box door to find out the issue. Looks like lint and the old grease causes it to gum up. Can't disassemble unless you have lots of time and energy to heat the door up so the sonic weld would come apart.
Thanks. I guess what I was trying to figure out is what goes wrong with these?Netjunky (thread starter) posted this on the last page.
I have a 2009 LX570 and have been frustrated with this issue for quite some time. Thanks to the posts here I decided to dig a little further into this issue. My first thought was to disassemble the halves of the door and heavily lubricate, but the above post about heating up the door was a no go for me. So I decided to move on to the next option, a small discrete hole in the middle of the door. I used a 1/4 inch drill bit, directly in the middle of the inside panel of the door. Upon drilling the hole and looking inside I saw a Phillips screw head. I loosened the screw about 3 turns, pulled the stuck latch to the extended position and while pushing and pulling the latch continued losing the screw until it moved freely in and out on its on. Once I was able to get the latch moving freely I just slowly tightened the screw until I was satisfied with the resistance. Worked like an absolute charm. No expensive new door, no heat and just a small hole on the inside of the door that will never be noticed. I hope this helps anyone else with this issue. Total time, 10 minutes to perfect fix.
This worked like a charm. 30 second fix. you only need a 6-8mm hole. Kudos to the people who worked this outSame issue just happened to mine, also a 2008.
Before I start drilling, just wondering how hard is everyone yanking at the plunger with their pliers? Mine doesn't seem to want to move at all, seems like it's caught on something internally. Not sure if I want to apply more pressure and risk breaking the mechanism inside. Thanks1
Thanks for confirming! I just ended up applying a bit of pressure with the needlenose pliers and they just came out. They work well enough as is..This worked like a charm. 30 second fix. you only need a 6-8mm hole. Kudos to the people who worked this out![]()
Hey Ratchey..I tried drilling a hole as well in the midpoint, about 1" up from the edge but no luck finding the bolt. Can you kindly provide exact dimensions of where you located your drill hole? THanks...I ended up drilling two holes in the back side of the door. One in the center over the bolt and one to the right over the spring.
I used compressed air and blew out everything I could. Then took some plastic safe spray cleaner (for electronics or something I had in my collection) and really sprayed it out trying to clean up the dust and lint that had collected on the center bolt mechanism and gummed it up. Then I sprayed silicon lubricant spray on the center section and a little bit around where the tabs are that hold the door shut. I pulled the spring out but it seemed fine. The door works a lot better and stays closed but I don't think it is a permanent fix.
I do carry a small pair of needle nosed pliers in the glove box in case the tabs get stuck again.
