Gauging interest on PUMA air compressor 80 series mount
Initially I thought it might work but I am gonna say no because it seems like stability will be a problem
The prototype doesn't exhibit any stability issue at all can you elaborate on your concern.
What are the pros/cons , if any, to mounting on passenger side vs. drivers side?
Is one side better than the other?
I could see is a few less feet of wire on install for the drivers side. Some guys like the drivers side if they mount the spare upright to not block visability. It mostly about what works best for you personally. No clear cut advantage I know of.
isn't there a way the compressor could be mounted above the spare tire carrier under the vehicle and insulated against the elements?
I don't want to clutter up the interior of the cab.
a. Wouldn't take up room within the vehicle
b. No opening of windows or rear hatch to get access to
c. Less noise
I've seen it on an an FJ and am just hoping someone comes up with an 80 version.
Zona
I'm in for one...That compressor is on my short list!
I would think the thinner metal on the fender would give before this mount would? :meh:
Any updates? Have a brand new Puma compressor just begging to be mounted! :)
Funny you ask... the fabricator will be by within the hour to pick up my extra PUMA for fitting.
I'm in for sure once they're ready......
I've got the compressor can't wait for the mount!!!
My Puma arrives today...looking fwd to getting the mount!
I have the puma in the box waiting for the mount as well.
I would like the passenger side mount when it is ready.
Can't wait :)
Side note: Does anyone know what gauge wire the two wires are coming out of the Puma?
I want to order an Anderson quick disconnect for it, and thought some one here would know.
Thanks.
Thanks.
IIRC #10
Teaser pic
Simple, clean, and solid
Final specs to follow
