I had a shocking problem with the 100 this Father's day weekend out in Colorado. When climbing Hayden Pass I started to smell terrible gas fumes at about 10,000' and assumed it was the side-by-side ahead of me. Then fuel puked out of the sealed gas cap, yes it was properly secured. You can see the route the gas took to escape here:
I stopped at the top of this pass, a mere 10,700', and could see fuel vapor roaring out of my fuel cap. I cracked open the cap and noticed an immense pressure release. After 15 minutes of pressure relief, I went ahead and pulled the cap and it continued vent for another 5 minutes or so. The charcoal canister under the hood was also making a popping or groaning noise. I had filled the tank to the first click then drove 35 miles to the trailhead, so it had to be down a couple of gallons.
It was hot this past weekend. 100 degrees. Yes, it was 100 degrees above 10,000'. I had the AC running full blast and the transmission was locked in 1st crawling up in Lo. The motor never heated up and there was not much stress on the drivetrain. I have no doubt heat and air pressure were contributors to the problem, but there must be an underlying problem that allowed the heat and altitude to have such an effect. The day before I drove up as far as I could on Mount Antero, about 12,500' before the snow stopped me. It was in the 80's and I had no issues.
I will disclose that during the drive to Colorado, my CEL illuminated between Goodland, KS and Limon, CO then turn itself off. The drive home was uneventful. No CEL and gas stayed in the tank. I pulled the codes when I returned home and had 4 active faults. To my surprise, nothing related to the Evap system was stored.
P0100: Mass or Volume Air Flow Circuit
P0101: Mass or Volume Air Flow Circuit Range/Performance Problem
P0110: Intake Air Temperature Circuit
P1121: [Toyota] Accelerator Pedal Position Sensor Range/Performance Problem.
The codes are pretty straightforward and should be easy to remedy with exception of the cost for the APPS
I've searched for help but have come up mostly empty handed in regards to the fuel puking out the filler. I haven't found any report of someone actually losing fuel out of a closed cap or having the amount of vapor build up that I had. I did see a few people have had excessive vapor build up and said it could be the charcoal canister but dismissed the problem as rare and not a concern. The charcoal canister was also mentioned as the cause for the slight pressure released when removing the fuel cap most 100's experience. I'd like to do some more research on this as the charcoal canister is $$$.
What could be wrong? This is a stock 100 series. I've never has this happen with any vehicle before, so I don't even know where to start. Am I on the right track looking towards the Charcoal Canister?
