For Sale FZJ80 Rear E-locker 9.5" (1 Viewer)
I have a rear e-locker from a 1996 Land Cruiser in good condition. Bearings turn smooth, actuator motor engages and disengages smoothly. 4:10 gears 9.5" ring gear. 213XXX miles. Street and highway driven. Gear oil still really clear when removed. $600.
will it suit FJ60 rear? also has 9.5" differential if yes i can take it.
Double post
Pm sent
I can't be sure if it will fit a FJ60. You will need to do the research to find out.
Fzj80 rear 9.5' elocker and 8" high-pinion elocker
I now have a 1998 Fzj80 9.5" rear e-locker and a 8" High-pinion front e-locker.
Both in great shape, 4:10 gears, actuator works well and bearings turn smooth. Gear oil in both diffs was clear when removed. Harnesses with both. $600.00 Each
Is the rear locker different from the one you originally posted, or did you mix up the year ('98 vs. '96)?
Where are you located?
Yes, Its a mistake. They are both from a 1996. I am located in Liberty, MO 64068
You'll need long splined shafts for that to work in any other diff. That will bolt in a 60 series diff with mods on a FF axle or front axle but you will need the axleshafts replaced or modified.
You just need the long-splined long side if you're putting it into the front, or the long-splined short side if you're putting it into a full-floating rear end.
