would a h55f fit to the original chassis crossmember mounts will the 1hz bolt up to the 1fz chassis engine mounts? thanks
think ill keep the h150f and get hold of a bellhousing to suit 1hz/1hd, broke down about 20km north of coronation beach, not far from home (Geraldton)The H55F and t/case are shorter than the H15* type ,so it would need a custom crossmember to clear the panhard rods. I would go into a car yard and take some measurements of HZJ75 engine mounts.
Where did you break down? It looks like between Lancelin and Cervantes
yeah mate 14 splinesHow many splines does the 1FZ FE H150 have . I think the 1HZ has 14? splines[/QUOT
cheers mate, not to sure oil related possably, started knocking when I was out camping after going through some soft beach sand on the rev limiter then it locked up about 30meters from my camp the next day, pretty good engine besides this had 390,000kms on itSome strong work going on there mate. I'd love to have the 1fz engine in my fj73 what do you reckon killed it?
yeah most likely will keep it, need to chop a few plugs offAre you keeping the 1fz wiring loom? Is it in good condition?
yep front/main tanks ill change the rear at a later date never had the need to fill bothAre these the front tanks, the ones under the front seat?
