In this thread, I'm going to give a comprehensive summary of the full brake system rebuild I just did on my HZJ80. I'm going to walk through replacing the master cylinder, all the soft lines, front rotors, splitting and fully rebuilding the calipers, and replacing and calibrating the LSPV. Some of this info is on MUD here and there, but I was surprised how much was missing. I'm aiming to make this thread a complete reference for anyone who wants to work on any part of the brake system.
A few notes first. My 80 series is a RHD HZJ80, 1996 model. It has disc brakes front and rear. It doesn't have ABS, this spec vehicle didn't come with it. There will be some differences with LHD and ABS vehicles.
This is definitely at least a
job. It requires more than one day, attention to detail, and specialised tools you won't have on hand unless you've done a job like this before.
Right, let's get into it. Here's my 80:
Great vehicle. Had it for about 7 years now, been on a lot of adventures. I've had cause to marvel at how in the time I've owned it, I hadn't had to change the front brake pads. I got suspicious when the rears ran low recently, which I'd changed once before, that the front calipers were actually stuck. I also had a very slow leak on one of the hoses, and an aftermarket master cylinder from a PO that I wanted to replace. I opted to do everything at once, and go scorched earth, replacing everything with genuine parts and getting the brake system back to factory new condition end to end.
Almost. There are two things I didn't do in this process. First of all, my brake booster. It has no leaks, works well. I left it undisturbed. That's simple to do, because it's "above" the hydraulic part of the system. You can easily do the brake booster separately from the master cylinder down, and that's what I'd advise you to do. Secondly, I didn't replace my rear rotors. I replaced the rear rotors about 4 years ago, when I went scorched earth on the parking brake system, of which the rotors form an integral part. Everything else, I'll cover below.
First of all, you'll need a ton of parts:
Go genuine. Don't go aftermarket. Get genuine pads, rotors, lines, the whole set. I'll probably provide a list of part numbers in a following post. For now, feel free to ask questions here.
Time to jack up the vehicle and pull the wheels. Two sets of jack stands will make your life easier, but you could do it with one, it'll just mean more screwing around. I'll start at the rear:
Two bolts, 17mm from memory, holding in each caliper. Go ahead and pull them. You'll make your life a little easier if you break the slide pins loose too while it's still mounted on the car, but leave them threaded for now. Now it's time to disconnect the brake line from the caliper:
Leave the brake line dangling, drizzling a nice stream of amber fluid. A container below isn't a bad idea:
Repeat on the other rear caliper. Now let's pull the fronts:
Repeat for the other side. You should now have all the calipers off. I'm going to continue removing parts, now onto the Load Sensing Proportional Valve (LSPV). You've got easy access with the rear left wheel removed:
