Excellent write-up.
| SEAL, between caliper halves SKU: 583-820 | 8 |
If you don't intend to measure the LSPV pressures, your best bet is as you said try and mark the current position and match it. That did work reasonably well for my swap over. Obviously this assumes your current settings are right though, which may not be the case if you've done a big lift.Excellent write up OP! The LSPV on mine has the boot torn and I have a new LSPV plus the boot kit ready to go. Question…would it be possible to just make a mark or 2 with a paint pen on the LSPV and the metal “spring sensing” piece between the LSPV and the rear axle to avoid having to measure pressure? Wondering if it’s possible to simplify this proceedure.
Thank you for the reply. I have an HDJ81 with the stock lift…..it is 1990 model year (JDM) and suspect you are correct about the setting.If you don't intend to measure the LSPV pressures, your best bet is as you said try and mark the current position and match it. That did work reasonably well for my swap over. Obviously this assumes your current settings are right though, which may not be the case if you've done a big lift.
Honestly I suspect most people's 80s have LSPV settings that are significantly off. It can have a significant effect on breaking performance, especially in emergency braking. If you aren't getting enough braking power on the rear wheels for example, the rear could kick out. I'd suggest looking at the options for doing this calibration. It's only one peice of kit you need to make it possible.
