I think I know the answer but just want to make sure.
For my wife's '99 with 325k, the brakes had been feeling not as strong as they should be. They're not spongy, but if you pump them twice, it brakes better. No improvement with additional pumps. It's been well taken care of by the previous owners and ourselves in the dry south.
Replaced the rotors and pads with no change. I hate brake bleeds and flushes so had a shop perform it. They said there was a strange difference in pressure reading between the right and left side of the vehicle and recommended a very expensive master cylinder replacement.
Their explanation sounded odd and off so I wanted a 2nd opinion and took it to another shop who recommended a flush which I agreed to. Just as they started the vacuum on the system, they heard odd noises in the booster and stopped before any potential failure. They said the same in that the master cylinder assembly needed replacement and also recommended all 5 of the brake lines. Another very costly quote.
1st place quoted about $3,200 for the master cylinder assembly part and the 2nd found it for $2,300.
The unit on hers is Aisin. Is this OEM or has it been replaced prior?
From the other threads I've read about brake failure and issues like this one; Brakes ...... Overdue write-up. - https://forum.ih8mud.com/threads/brakes-overdue-write-up.1230968/, I'm assuming I need to move forward with this...
I've read of individuals getting some good deals on the master units but it's been a number of years. Anyone have a good safe source?
