Which grade of unleaded do you prefer? Have you seen a difference between grades in either mileage and/or performance?
Factory manual suggests no less than 87 octane. Being a poor college student, I uses what I can affords.
Not to be the party pooper here, but everything I've ever read or heard on the subject is that there are absolutely no performance or gas mileage gains from running higher octane gas through an engine built for 87. In fact, it can actually be worse for the engine. High octane gas is not cleaner or better in any way. The idea that the occasional tank of premium will clean the engine is a common misconception. The octane rating refers to something about the speed at which the gas ignites. If your engine is designed for 87 (like the 80 series) and you put higher octane in it, then the fuel burns at a different rate which means that your timing will be off. You're paying extra money for no purpose and could be harming the engine.
Pretty much anything short of water.
I'm serious. The 3FE was built to handle the crap they call gas in Africa. But I would recommend pump gas.
I put mid-grade in mine. It's funny to see the looks on people's faces when they see a 20-year-old hand the cashier $70 every week.![]()
These are very low compression engines fellas... Low compression, no supercharger, and factory set timing = 87 octane. Anything else is a waste IMO.
Sometimes I run 100 octane in my 3fe and I run 12.4 second quarter
