I have a 2f with a Weber 38 conversion that I am trying to put back together after a frame off conversion. Is there a correct way to plumb up a weber for the return line? I don't want to smell vapor while I'm driving down the road. Before I started the frame off the weber's air cleaner was always covered in fuel. What does that mean?
All the fuel lines that are hard mounted to the body of the truck, what should I use those for? I currently have the soft line running off the bottom tank to the hard line that is bolted to the frame, to the fuel pump. Is this correct?
I have a leftover charcoal canister, fuel seperator, and all these other lines that I feel like I should be using.
Help please. Getting this truck running would be a X-mas miracle.
Cruisers=
at the same time.
Cruisers=
