Fuel line leak (2 Viewers)
knoxville, TN
Looks like now I have a fuel line leak. What do I do to relieve the fuel pressure to slow down the drip while I find a repair kit?
For one thing, loosen your gas cap where you fill it up.
And just to be sure…what vehicle & engine to you have?
Can’t really find anything online concerning a process for relieving pressure before removing the fuel line. I found one thread in another forum where the owner simply loosened the gas cap and removed the negative battery cable as a just in case. I would hate to remove the fuel line only to find out that I got air in the line that became difficult to get out of the system. Maybe I’m overthinking it (wouldn’t be the first time)? For clarification the fuel line in question ties into a rubber hose (held on with the typical Toyota hose clamp) going into the tank and a flared nut along the chassis towards the front (well before the engine bay). I will get pics of those tonight. Oh and I ordered some 5/16 aluminum fuel line from the Zon and will need to get a flaring tool. As well as a tubing bender. Unless it’s a small pinhole leak and maybe I can get by with a simple union.
Pretty sure there's no in-tank pump and the fuel line is under vacuum up until the lift pump mounted on the IP. I've fixed failed hard lines by cutting off the damaged section, cleaning the outside of the hard line well, slipping standard fuel line over the remaining hard line with no flaring or ribbing, and using a couple quality hose clamps.
If your state has a biodiesel mandate then quality fuel line is very important, biodiesel will shred anything not specifically rated for it. Even small concentrations of biodiesel will eventually damage fuel line not rated for biodiesel, it'll just take longer. I like Gates Barricade hose.
