4Ruster
2LT Sufferer
Hey all. I've been recently looking into modifying the stock governors for our rotary injection pumps. It used to be popular with the 1.6TD Volkswagen guys, however the same tricks can easily be transfered over to our pumps.
There are two styles of governors.
The pull type all speed governor uses a pull type spring and is common on Cummins as well, the only way to modify those are to use a stronger spring. I will not get into that as I want to mainly focus on the next style
The cage style governor uses 2 compression springs and acts both as a throttle smoother, and the speed governor.
Here is what mine looks like.
Now to get into the modifications
From what I've read,
From left to right, we have the idle/start spring, the intermediate spring, and the main spring.
> The idle spring we will not focus on, it's purpose is to maintain a smooth and steady idle speed.
> The intermediate spring acts as a sort of damper, it's smooths out the throttle response, I've read when people shim this spring, it drastically reduces drivability.
> The main spring is what controls when the fuel starts pulling back on us. If you want to raise that RPM, you stiffen the spring by adding a shim.
I will add a warning, shimming the main spring will mess with the no load speed governor, so be aware.
I installed a single washer on the main spring here,
I will update you all on how that goes.
Please feel free to jump in and share your knowledge on this, the more information, the better.
