What is a good way to get a the fuel filter? It is in a rather peculiar spot...
Thanks, jt
Thanks, jt
How tough would it be to move everything out from under the intake during say...................a HG job where the upper intake is removed?
Beno- i recall you moved your wiring harness out...........did you move all the other stuff out as well?
Onur, when bugsnbikes mentioned you moved you wiring harness, did you move it just for the HG or did you re-route it permanently for some reason?
If i recall- he hacksawed the lower intake(which wasnt removed for the HG job) joint--slipped out the harness- and welded it back together.
The runner split apart too much and lost structural integrity.
