Additives in higher octane fuel retard combustion which prevents pre ignition AKA pinging. If your engine doesn't ping with regular octane fuel there is no benefit to running higher octane fuel.While premium might not result in a better value in terms of $1 spent vs mileage traveled, there is some misinformation here about premium like that it burns slower or has less energy content. It's actually quite the opposite due the ability for more compression, which ultimately will release more energy per unit consumed.
When we lived in Reno and did the bulk of my driving at and above 4,500' elevation I, after much experimentation, found running 87 octane was compression friendly. Now at sea level 91 octane seems to be better. Makes sense given the density of air difference.
Of course ethanol throws in its own curve ball...
But the word "economy" and Land Cruiser (petrol) should never be used in the same sentence
Blame your local corn grower.Ethanol is one of the biggest POS policies that the Government has ever pushed down to industry. E10 gas lowers MPG 3-5 % (I think more), can tear up engines that aren't specifically designed to run on it, and I'm sure after producing it and passing the cost down to the consumer the gas isn't any cheaper. I'm not sure about other states, but if you are in a metropolis in Texas, there is no E0 fuel available.
http://pure-gas.org/
11 seems low to me. Average in town for me is about 12.5 mpg and on the highway is around 17.5. Over the course of 10k miles I averaged 14.5 mpg.
That's on 285/75/16s with a front bumper and 1.5 inch lift.
My 11 mpg is uncorrected for larger tire size, not that it makes much difference. I am curious how much the CA blend impacts things. @spressomon you moved to CA from NV, right? Have you noticed a difference?
How exactly does timing effect compression?It's not so simple as days of yore when cars had a single timing map. Modern day ECU's are very capable of advancing timing for more dynamic compression to maximize efficiency (power) from higher octane fuel.
Keep the RPM's below ~2100-ish when pushing on the skinny pedal, either accelerating or maintaining freeway-type speeds, and you'll see improvements.
