fuel cut off switch reset
The manual I have for an 02 LX says its in the DS (USA side) upper footwell. Push and hold for more than a second to reset. Hope this helps.
Sent from my iPhone using IH8MUD
should the buton be up so you can not see it or the can you see it when it is good
Manual just says "push and hold for 1 second to reset" with vehicle stationery on level ground.
it dus not seam to do any thing
Are you sure the cut off is active? Does it throw a code when this occurs?
I'm interested in what you have going on there. If it's just not pumping it could be a lot of things I suspect.
