FS: Excellent Off-Road Trailer - CA
Selling my OR trailer. This trailer was built by Wayne Percival about 5 years ago. Along with the trailer, the buyer will receive a 10% discount on any AutoHome tent in stock.
Here are some specs/features...
- Frame is 1/4" wall, 2" square steel tubing - powder coated black
- Swiveling pintle lunette
- Extendable tongue goes out to 5' long
- Spare tire carrier to fit 6 on 5.5" rim with 31" tire
- Delta tongue box with two nesting aluminum tool boxes
- Dual 105 AH marine lead acid batteries with marine quality battery frames and hold downs - Mounted in tongue box
- Guest Marine 2 bank 10 amp charger with external plug in side of the tongue box
- 12 V outlet in side of tongue box
- 1.6 GPM Shurflow water pump plumbed to spigot on side of tongue box (operates on demand - ON/OFF is a protected toggle inside tongue box)
- Lid is aluminum powder coated white, with continuous, heavy duty stainless hinge at the front
- Lid fitted with Yakma Landing Pads to carry gutter mount towers and cross bars
- Tail gate (48" X 27") opens independent of the lid
- Box is 48-1/2" wide on floor, 72" long, sides are 27" high
- Fuel can carriers with four 5 gallon Blitz fuel cans - carries 20 gallons of extra fuel
- Water proof tail lights match Land Cruiser - two red, two yellow, plus license plate light.
- Seven pin connector
- 38 Gallon water tank between the frame rails and rear of the axle - 3/8" welded ploy with 1/8" thick powder coated steel skid plate. Stainless filler pipe at rear PS.
- Axle is 3500 lb. HD that is the same hub-to-hub measurement as an FJ60 and has 6 on 5.5" hubs. Leaf springs and sprung over - 12" ground clearance
- One rod in the rear PS latch is damaged - needs to be re-threaded (latch part is in the tool tray in tongue box)
- Spare tire included
- California permanent trailer registration - plates are current
- Wheel chocks, water proof axles grease, water filler hose and cable lock in the tool box
Trailer is has a red box, white lid, black frame - all powder coated. Good condition, every thing works, tows extremely well empty or loaded. Trailer usually weighs 1000 to 1200 lbs. LOADED. Pictures to come.
Price is $5000. This is about 50% of replacement cost.
Available for viewing at Mudrak Custom Cruisers in Sonoma, CA. 707-292-3509
Or call me at AutoHome - 888-852-2359
PM sent....
DROOL.
wish I could afford that -- it'd make a wicked SAR base camp!
SOLD.
