I am selling this set of 4 Bilstein 5100's off my 40 which has an approx. 3" lift. I loved the ride and performance of these shocks but changed to an adjustable shock that I felt was better for my softer spring set up. Made in Germany, not China
There are some surface imperfections in the zinc coated exterior housings. Eyelet to eyelet design - all bushings are in great shape. All 4 shocks feel very strong still.
Description from Summit Racing:
These Bilstein 5100 Series shocks feature a monotube design for cooler, more efficient operation and longer life. They have the largest available piston diameter, providing superior handling and performance. The 5100s' patented digressive valving instantly reacts to changing surface conditions for maximum comfort and control on and off the road. These shocks also have split compression and rebound tuned valving.
Additional features include:
* 2 in. seamless extruded tube
* 14mm centerless-ground, case-hardened, chromed, and super-polished rod
* 46mm Bilstein digressive piston
* Self-adjusting, deflective-disc independent rebound and compression
Measurements:
Fronts: 5100 Series, 22.50 in. Extended/14.060 in. Collapsed Length, Eyelet/Eyelet, F4BE56253H5
Rears: 5100 Series, 25.93 in. Extended/15.91 in. Collapsed Length, Eyelet/Eyelet, F4BE56248H5
$125 for the set . PM if interested, thanks
Measurements:
better use than my parts shelf, for sure
