having a lot of difficulty with this annoying problem; but first the nomenclature.
My 1997 Factory FSM (Canadian for LX450) page 'SA-42' shows the diagram for (front components) the 'Stabilizer Bar' .... at both ends the Stabilizer Bar has an eye. The FSM illustration shows, as a seperate component, what it refers to as a 'Stabilizer Bar Bushing' (as well as a bolt and nut) that is intended to be inserted into the eye (one for each end of the Stabilizer Bar) .....
To reiterate the name given by the FSM to this part is 'Stabilizer Bar Bushing' .... which is NOT to be confused with the another pair of bushings called a 'Cushion' by the FSM (a pair of split 'D' shaped rubber grommets) that surround the Stabilizer bar and is held by a 'Cover' attached to the 'Stabilizer Bar Link' .
My problem is that every search I make for the 'Stabilizer Bar Bushing' ... turns up these darn 'Cushions' ...
While I do want to purchase 2 'Cushions' for the bar as well ... I real need these end components ('Stabilizer Bar Bushing')as passenger side end has no bushing material remaining and makes an annoying bang every time the Stabilizer Bar is brought into action.
Any help -- and source/part numer would be appreciated
(I am hoping ... since my FSM indicates that the 'Stabilizer Bar Bushing' is a 'non-reusable part' that I can source it without having to change the entire Stabilizer Bar)
thanks!!
thanks!!
