It shouldn't because compression travel is governed by the bump stop on the lower control arm. Bad things happen if the shock were long enough to become the compression limiter.
What size spacers did you end up using front and back?![]()
Installing the spacer on my LX currently. Was able to confirm that the spacers absolutely increase suspension stroke by giving more droop travel. Pretty awesome for such a cheap mod.
Measured 21.125" from top of brake hub to fender stock. 21.875" after.
.75" gained in droop travel! On the more constrained front axle! That may not seem like much but it can surely help the already astounding RTI of the 200-series platform and maintaining traction. Enhance compression travel on whoops.
So the tools necessary for this job are the spring compressor? And that's it?![]()
No spring compressor necessary. I wasn't getting enough droop to release the top hat of the coilover and tried to cheat. The right solution was to release 1 of the two inboard lower control arm bushings (don't need to do both per the video), and the end link of the sway bar at the LCA.
Need a full complement of wrenches, socket sets, and torque wrenches as this is practically a full suspension job to install the spacer.
Here's the best reference I found. Another big thank you to @OTRAMM
Bumping this -- curious what exactly we need besides extended brake lines for the E&E rear shock extenders. Exactly what bump stops and what spring spacers?Been looking for something just like this, including all of your comments, so thank you very much! Got my accumulators from Japan today!!! Literally took less than a week! Together with my 10mm front shock spacers, (i need to order some 20mm for the rear, but maybe 30mm?), and the E&E rear shock extenders. All of those with an appropriate sensor lift and I should be able to dial the pressure back to stock. I'm able to find the pressures for the AHC at each wheel in TechStream, which is how I readjusted it previously (adjust and readjust, manually). Oh, and I already have the BOTCK from Dr. KDSS.
You don't technically need extended lines for the E&E shock extenders, but if you couple it with an AHC lift, they may become desired (if stock lines are overextended). I'm running PerryParts bump stops with 25mm of spring spacers on the rear.Bumping this -- curious what exactly we need besides extended brake lines for the E&E rear shock extenders. Exactly what bump stops and what spring spacers?
And for the front, just the spacer?
For the rear spacers I recommend the following:Bumping this -- curious what exactly we need besides extended brake lines for the E&E rear shock extenders. Exactly what bump stops and what spring spacers?
It's been a while, but I am seriously looking into getting a 2020 LX570 and have a potentially stupid question regarding the front shock spacer.
- would it be a dumb idea to cut a slot in the spacer for install to avoid having to bleed and disconnect/reconnect the system?
I don't own an LX but from what I remember looking at my friend's, this still wouldn't work. The AHC tube into the top of the strut shaft is at a right angle, and I'm pretty sure you wouldn't be able to pull the strut down far enough for the studs to clear their holes in the spring/strut mount on the frame, let alone get down far enough to deal with the downward "cup" shape of that mount to slide the spacer in between it and the top hat of the strut.
I have yet to install mine, but I don’t think you can get the spacer in without taking the shock out and you can’t do that without removing the hydraulic line.It's been a while, but I am seriously looking into getting a 2020 LX570 and have a potentially stupid question regarding the front shock spacer.
I thought about that approach (or even cutting it in half), but after adding the spacers, I can tell you for certain that you won't be able to get a spacer into the bucket without removing the hydraulic line, and even then you can't just "slip it in".It's been a while, but I am seriously looking into getting a 2020 LX570 and have a potentially stupid question regarding the front shock spacer.
