Who has replaced their lower control arm bushings? I've read as much as I can around here, but haven't found a consensus on doing these other than they are a pain.
I'm replacing the uppers with adjustable, and know that those bushings are worn out. The lowers I can't tell, they seemed pretty good (rebounded to preload and I could almost stand on them without them moving too much. I tested them when I did the torsion bar swap to OME and had the lower arm freed up.
I have no symptoms to indicate there is anything wrong with the lowers, although I know they are original. They would end up being the only 'consumable' front end component that hasn't been updated within the last 2 years and I'm interested in folks feedback on any improvements tied to replacing them.
Having done lots of bushings over the years, when it comes to Toyota's that have the cam/eccentrics in the lowers, I have sworn to never deal with them again myself as they seize and snap off or break cam tabs. These NOT being eccentrics I'm interested in if there is a real benefit to doing these at 200k. If its actually a sliding scale of diminishing returns though and I'm going to put in 5-6 hours for something with very little return I'm happy to skip it. I don't see a way to verify if they are going bad.
