I'm disassembling the front hub and when I remove the hub bolts to separate the rotor from the hub, I discover that some chicken f#cker forced a 1/2" x 13 bolt into the axle hub and it doesn't appear that the redrilled or tapped the hub before doing so. I'd like to repair it with a helicoil and hopefully get a OEM bolt to go back in there (Bolt Flange - Toyota (90080-10395)). My question is for the repair. Is the OEM bolt a M12x1.25 or M13x1.25? I don't have a way to figure the diameter but the threads are 1.25. Any help will be appreciated!
The involved components.
Mr Toyota's fine equipment on the left and, on the right, the unfortunate result of some marginally functional mouth breather that should have been put down at birth.
Thanks in advance!
Thanks in advance!
