Easiest way to pull the end of the CV is to screw a M8 x 1.25 bolt into the end and give it a yank, it is threaded for this purpose. I also highly recommend ordering every available c clip, I think there are 5 for one side and 4 for the other, so you have them for the rebuild...they are only about a $1.500 each and you need the thickest available so the axel doesnt move in our out.
/QUOTE]
I had a bolt in there and with all 200 lbs of me it wasnt doing the trick. But with the right amount of grease it should. I have pulled my CV's a few times. This was the first time I ever had problems.
For others - the Clips are cheap like noted. Myself and a few others here keep 2 of each size for jobs like this. I think it is solid advice.
Or why don't we just get Dan to post up the instructions here and make it a sticky! Like Smuckers, if it comes from Spressomon, it has to be good.
There is already a thread/instructions in the FAQ. It is really good and straight forward. The only area I found a little unclear is the Preload. But there is info on it linked in the Bearing replacement FAQ now. Seems a more than a few people have found the FSM torque values for setting the preload is too low. After opening mine up and finding everything loose, I tend to agree. I followed what some others have been doing and will see how it goes.
